engine noise while winterizing!
jim911
Running fuel treatment through 2006 4 stroke 50 hp merc ,water flowing well, pulled fuel line to run out of fuel and during that time the motor started to clatter which would increase or decrease with slight rpm changes. Turned off ,nothing hot, oil fresh and full. what happened?
jimg984
Re: engine noise while winterizing!
sounds like a 4 cyle engine when it is lean on gas or low octane
and you were running down gas supply so pro was lean others on here will give more help
