Swampmouse
- Joined
- Feb 2, 2007
- 121
Guys,
Many of you have helped me over the last year on doing a rebuild opn my 1983 Johnson 115. Thank you for all the help you have given me!
Last Saturday I finally got it on the water - I was trying to get a working tach so I could do a link and sync, but could not wait any longer. So, I got the boat to the lake, engine idled well.
When I got out of the no wake zone and let her rip, it would not come up to speed. Since my speedometer does not work, I would guess that I was going probably about 10-12 mph. Not quite fast enough for the boat to plane out. When running, the speed was indicative that I should have had about 80% more throttle.
I should note that I recently replaced the throttle cables.
My guess is that somehow I did not have the cables adjusted properly, but they SEEMED right.
Is this a timing problem - remember the engine idled good and in neutral would rev up very high if I moved the lever all the way.
Any suggestions?
Thanks,
Sm
Any suggestions?
Thanks,
Sm
