egldvrbags
- Joined
- Sep 8, 2007
- 105
Bayliner 2050LS 1995
Engine model: MCM 4.3LX Alpha 1 gen2
Engine sn: 0F436164
Last weekend after running for an hour or so, I put my boat in the lift for the weekend. Before leaving, I checked the engine oil. When I first pulled out the oil dispstick, it was dry....yikes. I put it back in, pulled back out and it showed full. I always watch the oil pressure when running (plus has an alarm) and didn't notice anything unusual. I just thought maybe the dipstick had come out a little during the run and hadn't noticed it when I first pulled it out.
This weekend, as always, I checked the fluids before starting. The oil dipstick showed full when I first pulled it out. I wiped it off, checked again and indicated full. I made sure that it was pushed all the way in before leaving.
Ran for about an hour or so, oil pressure 40psi at idle (after warming up) and 60psi when cruising - these are the numbers that I've always had.
When I put the boat away, the exact thing happened.....made sure the dipstick was all the way in, I pulled it out and it was dry. Reinserted, checked full.
Any ideas?
Thanks!
Bags
Engine sn: 0F436164
Any ideas?
Thanks!
Bags
