Finally got around to winterizing over the weekend. Everything went OK, (thanks Don) but when draining the engine oil I could only got 3 qts. Supposed to hold 4 and yes the dip stick said full before I started. The outdrive only gave up 1 1/2 qts., supposed to hold 2. Is this normal? Both drained per manual instructions. Boat level or slightly bow high and engine warmed up.
Merc 3.0 with Alpha 1.
