3.0 L 140hp gm engine, alpha 1 drive. The water hose detached from the drive and the engine overheated while tubing last weekend. I fixed the water hose when I got home and started the engine. It was a little hard to start, but seems to be running OK. I found pieces of the exhaust flapper in the exhaust port, so I know that needs to be replaced. The engine appeared to be totally dry when I hooked it up to the hose.
What else should I be looking at for damage?
Can I install a temperature alarm on an old (1987) engine? With my attention focused on the kids and the tube, it was too easy to miss the overheating engine.
