A friend just purchased an '88 boat. Took it for a 2 hour test drive with no problems. The next day he took it out for a ride and it began to overheat. When he shut it down, there was a little smoke/smell from the engine compartment and the temp. gage read 190 degrees. <br /><br />He asked me to take a look after it had cooled down and mentioned that he may have run through some weeds and mud in a shallow end of the lake.<br /><br />The motor is a 3.0 liter (I think 130HP) OMC I/O. I asked him to forward the serial number since I fogot to get it.<br /><br />Here is what I did to help diagnose the problem.<br />1) got in the water and verified the outdrive water raw water input was not full of weeds and mud.<br />2) pulled the small (looks like 3/4") hose that goas from tansom to circulator pump (the pump bolted to the from of the motor) and turned over the engine. no water was pumping. <br />3)Pulled off the circulator pump and it looks fine (probably did not need to do this but did it anyway)<br /><br />So here are my questions:<br />A)I assume there is another pump or impeller in the outdrive, is this correct?<br />B)If so, is it located in the top end or the bottom end of the outdrive?<br />C)If there is an impeller in the outdrive, can it be changed / repaired with the boat in the water and is it an easy job for a backyard car mechanic?<br />D)Anything else I should look at?<br /><br />Thanks in advance<br />D)
