I run twin 1993 Evinrude 225's , the port engine will not **** at any RPM unless both thermostats are removed. Have tried several newish thermostats and it makes no difference. At idle with t'stats in, the engine does not over heat even though there is no flow at the telltale but at 4000 RPM it overheats in 2 or 3 minutes . Take out both thermostats and there is no overheat at high RPM either but the tachometer goes beserk at high speeds reading correctly then nil then 1/2 what it should in a constantly changing pattern yet the temperature guage reads normal. Could the voltage regulator be overheating even though temp guage shows all is normal - both side of the block remain just warm to the touch or is this an unrelated non cooling problem with the voltage regulator which is 6 months old and allways seems to go nuts in an overheat situation . Could toe in/toe out incorrectly set be causing this as this is the only adjustment done before this started but no cavitation audible.<br />Any thoughts appreciated
