After a long road of troubleshooting, im still having trouble with my 1989 mercury 2 stroke 60hp outboard. My top speed is 7mph (on a 15ft fiberglass bass boat), and I just sent it in to the shop where they told me I had a spun prop, bent prop shaft, corroded carrier bearing etc., and they repaired all those lower unit issues that they found.
After a trial in the water today, there was almost no difference in speed/power. Another frustrating thing is that my boat is not equipped with a tachometer.
My ignition system is completely checked out ( i believe), I have a 3/8 spark air gap from all spark plug wires. I have changed out the power pack and spark plug wires as well just to be sure and still no difference.
The only notable thing is that I have 120psi in the top cylinder, and 140psi on the bottom two. Could this indicate something wrong with my top cylinder?
