haulnazz15
- Joined
- Mar 9, 2009
- 3,720
I was looking to see if anyone had any suggestions on prepping a 351 Merc engine that has been sitting idle for about 2 years or so. We did a transom repair this past Fall, but the boat sat for about a year before that and has been sitting on an engine stand since we yanked it out last summer. It was winterized at the time (more or less, mainly just drained the water from the block), but I am mainly concerned about lubrication during the first minutes of operation assuming it actually fires up.
My plan: I bought new plugs, so I planned to spray some WD-40 into each plug hole and rotating the crank by hand in order to get some lubricant on the cylinder walls. I am also going to change the oil/oil filter prior to start up. Any other items I need to look at or different way to go about what I am doing? The engine is still out of the boat, so pretty much everything is accessible.
I just put in new exhaust shutters in the y-tube, and all new gaskets on the transom, so this is just engine-only prep.
Appreciate any thoughts or suggestions!
