Briandale92
- Joined
- Aug 2, 2011
- 9
I have a 87 mercruiser 3.0l and i just got a new upper unit put on the sterndrive. I went to take it out for a spin and cranked up fine and idled for a little then went dead. (Seemed to run fine when it ran)I tried to crank it back up while giving it a little gas and when it cranked back up it idled way to high and i shut it off as fast as i could. I tried to crank it back up and nothing. Got to the house and hooked the water up to it and it cranked up but with trouble and was making this horrible noise in the engine. Did a compression test and first cylinder read 190 second 90 and three and four 0. I took valve cover off to see if it was a rod broken or bent and all rods are fine none bent or mushroomed at top. I aslo set valves back. Still will crank but with aweful noise, wont stay running either. What is the most possible thing it could be?
