novice boater54
- Joined
- Jul 20, 2008
- 42
I just purchased a 1969 85 hp johnson v-4 and didn't hear it running. It apparently has been converted from points to breakerless electronic ignition by some one.I did have it running for a few minutes then it died and it appeard that the power head may be running a bit warm so I removed the lower end and replaced the water pump impeller.
It has a bombardier amplifier module. It came with the contols for electric shift and key switsh taken from dash of previous boat. The wires were marked for reassembly which I made a diagram of in order to install on my boat. My problem is that the engine ran for a while but started with some difficulty and then hasn't ran or fired very well. I notice that when I short the solenoid to engage starter with key on that the spark plugs only ignite when releasing the solenoid. Could a wire be connected wrong to the key in order to allow spark only when releasing the key instead of cranking the engine? I have abother problem too is that when cranking the engine it fired and while the starter was engaged it apparently bent the starter shaft and now I have to replace or rebuild the starter?
By the way is compression of 100 on three cylinders and 95 on the fourth a bad sign?
Any help is appreciated
