Engine Problem
bass fisherman
I have a 120 Johnson Motor. It will start & idle good,but when I start to give it gas it acts as tho it is running on 2 cyclinders. It takes about 10 minutes of starting to get it to smooth out . Finally it will clear out . I will get it up on
plane then it will die.I can pull the trottle back & it will start back up.
It will do this about 3 or 4 times,than it will clear out & run fine. If I take it out the next day, it will run good. If I let it sit for a week, I have to go thru the same thing again. Any ideas what might be going on?
