65' 90hp Johnson--Takin her out to troubleshoot some steering issues and prior to leaving ramp skeg got stuck in mud. Tried reverse, kicked up a ton of mud would not budge. I do believe the prop even stopped turning while about 1/2 wot. [newbie
] Got out and pushed her away and took off. 2 0r 3 minutes after reaching wot, engine bogged down and died. No start. Drained battery while trying to start. [another issue I'm trying to troubleshoot--charging system. Any help here would be appreciated also.] Engine hot enough to not pass touch test. <br /> Have not had a chance to check the obvious, spark, fuel, compression, just wondering if this sounds like mud might be the culprit? Or could my charging issues be a factor? Will update with more info. on spark and fuel, just wondering in advance about the mud mistake. Thanks. Daryl<br /><br /> [Just recently replaced fuel pump diaphram and filter. New points, condensor, rotor, coil, impeller, plugs and t-stat. Bulb stayed firm but not as firm as usual. Plugs looked slightly fouled but wet with mixture. Had the boat out only once before and I ran it for about an hour without any problems. Engine does have an exhaust leak I believe is coming from just below the powerhead. Carbs. need a rebuild, but are functioning well enough at this time.]
