engine racing after long run
captainzac
2001 6.2 mpi B3
Sometimes after a long run the engine wants to idle fast but not all the time
When it is acting up and I go from Neutral to forward or reverse it almost wants to stall
Thinking it might be the IAC valve but not sure
Any body had these symptoms before?
Harry
Don S
Re: engine racing after long run
Could be something as simple as the throttle cable getting worn or sticky. Check the adjustment and make sure there is a slight preload to the idle position when you come back to idle.
captainzac
Thanks but
what do you mean by a preload?
Harry
captainzac
OK
assuming that the throttle is not preloading all the time and is due to being sticky
What is the lubricant that you would suggest to use?
I was going to lub it because it can't hurt anyway
Harry
Don S
You don't lube the cables. The reason it's a little loose is just wear inside the cable. Just adjust a little and it will be fine.
captainzac
Thanks
I will let you know the results on Monday
Harry
captainzac
K
Ran the boat for 8 hrs this weekend.
Not one problem
Checked the loading on the throttle and it did have some pressure against
The stop.
Sooo
I bought a IAC and I am going to keep it on the boat just incase
I also am going to keep the tools to adjust the throttle just incase
I guess I will just have to wait until it happens again and when it does
Open the engine and see what I can find
Thanks for your help
Harry
