Re: engine re-mounting
If you have a mercruiser, you need an engine allignment tool to stick through the gimble bearing and line up. If you didn't mess with the front motor mount adjustment, you should be pretty close. After installing the engine, side the allignment tool through the gimble bearing and into the engine coupler. You'll feel it. If it slides in easy with two fingers on the tool, you're set.....if it doesn't, you need to adjust the front motor mount up or down.
