If it's not one thing, it's another. I have been fighting a lean sneeze at idle. Everything was fine otherwise. I decided to pull the carbs and soak them for a few days to try and fix that problem. I reassembled and headed to the lake.
Everything was going as normal and we idled/slow trolled around the cove to see how it was going. Sneeze was gone! I punched it to get on plane and the boat bogged down and died. Wouldn't stay running unless I held the choke and it wouldn't go above 5mph.
So I held the choke and headed for shore. Beached it and pulled the cover. Nothing seemed out of place. My choke solenoid has a red lever (I guess for manual start). I turned it to the other position and sure enough, she ran. I headed out to deep water and idle/troll was good... or so I thought. Something didn't sound right, but I thought it was because the cowl was off. Punched it to WOT and... it didn't want to go. It would go about 6mph and no more. Every 5-10 seconds it would go high RPM like it wanted to hit full throttle but it would immediately bog down. While the throttle lever was on full, I reached back to the bulb. Still hard and good. If I pumped it, the RPM's would increase but not even close to full.
Headed back to shore and noticed something I didn't the first time. One of the barbs on the choke solenoid was broken off and the hose dangling. Fuel was constantly squirting (which I now know was because I turned the red choke lever to manual... which is also why the motor would idle without holding the choke... and probably why the motor sounded odd. So I pulled out the trolling motor and headed to the ramp.
Such an interesting evening. Anyway, would the broken barb on the choke cause this problem? My gut tells me that the motor was starving for fuel. Why, I don't know. When I reassembled the carbs, I did the blow test upside down and rightside up to make sure the float was seating properly, which both were. I made sure all passages were clean and free. The only thing I did different, which I wonder could be a problem, is I used a gasket compound on the bowl gaskets. Don't ask why I thought to do that as the old gaskets are still practically brand new. I was careful not to put too much or block any passages, but I wonder if tightening down squeezed some out and may have blocked a passage (just my luck!).
Suggestions, thoughts, ideas?
The motor is a 1984 Johnson V4 115, but it has parts on it from other model years (previous owner Frankensteined it).
