engine removal, capping fluid lines?
ker
probably a basic question, but when removing all the fluid lines in prep to removing the engine, what do I plug them with? I have clamps for the fuel line but what about the hydraulic lines and such?
Bt Doctur
Re: engine removal, capping fluid lines?
Be easier if we knew what engine you have
boat127
i use golf tees for rubber fuel lines that way it doesnt damage the line like a bolt would.
for hydraulic lines i usually jsut tape them off with a plastic cap of some sort then jsut wrap a rag around them
Bt Doctur
plug the fuel, unscrew the power steering hoses and strap to engine, cylinder will not make a mess unless to turn the steering wheel
