need info on how to remove the Buick V6 From the OMC Drive, have removed all bolts visable but the engine will not separate from the drive, do I need to remove the outdrive first?? How is the flywheel attached to the drive. I dont see any normal bolts like you would see on a flex plate. Any help greatly appreciated.<br /><br />David
