engine removal problem - 1973 merc 3.0L
aries8888
Not sure if I am doing this correctly. I think I am misunderstanding the instructions when it comes to the gimble bearing / coupler area. Do I need to remove the gimble bearing prior to engine removal. I have removed the 8 bolts on the transom plate, engine mount bolts, linkages, etc. It looks like the engine is ready to lift out. The question is whether it is still attached to the transom plate and whether further disassembly is required. Thanks.
Clams Canino
Re: engine removal problem - 1973 merc 3.0L
You need the I/O board. This is for Outboards, not Mercruisers.
-W
