engine removal question
BIGKASH
I bought a 200 merc 1983 motor to replace my blown merc 200 that currently installed on the boat...I was just thinking today that I should just swap out the power head:My questions is <br /><br />1: the whole motor and drive shaft I bought is laying on a table how hard would it be the seperate out ? I have a repair maunal and looks like there is 10 bolts that i have to remove...<br /><br />2: or you think i should just replace the "whole motor & lower unit all together.<br /><br />thanks guys for the past questions answered, this board move real fast
Hooty
Re: engine removal question
If you know your l/u is good, I'd just switch out power heads. Quicker and easier.<br /><br />c/6<br /><br />Hooty
JasonJ
I would say just swap entire outboards. Its easier than swapping powerheads in the fact that you are not taking the chance of damaging something swapping powerheads. Its a Merc 200, so its a twenty horse motor I assume, and it doesn't weigh much. I am not a fan of swapping parts here and there unless combining parts from several sources to make a working thing. Here, you can just swap the entire mess, and it it a whole bunch easier to hook up a few cables and wires than unbolting powerheads, trying to find or make gaskets, and all that, and it takes a lot less time as well. Now, if its a 200 horse Merc, than it may be easier to swap powerheads only, but from experience I can tell you that you'll still need an extra pair of hands to lift that powerhead off. If it were me, I would swap the entire package. Either way, good luck.
BIGKASH
thanks guys it is a v6 200hp merc, I'm thinking of doing the powerhead swap....I'm i gonna need a powerhead to lower unit gasket ?<br /><br />any other comments...thanks
Walker
Replacing the whole motor is a lot easier. You will need a hoist but you would need one anyway to swap powerheads. Disconnect the control cables, battery cables and power cables and switch engines. 4 bolts
rons boat
Boy do I ever agree with Walker. If you change out the lower unit with the motor laying on the ground, Good Luck, as you will need it. After the motor is switched it is much easier to work on the motor on the transom including changing out the Lower unit. A host is mandatory for replacing motors of this size.
