Engine removal
tinny
Hi,
Just want to know how hard is it to lift the engine off the boat and what is entailed.
I have an 18ft basstracker w 150hp Johnson.
Any advice is appreciated.
Thanks!
tashasdaddy
Re: Engine removal
disconnect all electrical, control cables, steering, remove bolts, have hoist ready, lift motor.
tinny
Re: Engine removal
Ok thanks.....what about putting it back on.
The reason I ask is I need to clean the steering tubes out...or replace them.
I did a semi celaning once but couldn't get them all the way out without taking the motor off. Now, however it is a necessity, as the steering is "froze up".
tashasdaddy
Re: Engine removal
good reason. steer tube in first, set the motor on the transon, bolt it up, basically the reverse of what you did when you took it off. take pictures before, in case you get mixed up.
tinny
Re: Engine removal
Thank you Tashasdaddy. I just wanted to make sure there isn't anything super specialized about it. I appreciate you taking the time to respond.
Gary H NC
Re: Engine removal
Have the hoist hooked up to relieve a little pressure off the transom bolts and it makes it pretty easy to get them out.
