Re: Engine Removal
As a firm believer of the "RED-GREEN" approach to boating and boat repair I like the backhoe idea the best. If you do not have a buddy with one don't be afraid to go to the nearest farmer (with a tractor) and axe his advice, he may have a "hay fork", or "front loader" bucket to use. <br /><br />If you're going to do the tree limb be VERY careful about the limb cracking. DO NOT winch on a pine or softwood tree, they can't hold it. Go for your hardwood. Also consider using TWO winches, one to lift the motor, and one to brace the limb to the main trunk of the tree-<br />I see using a tree limb that is no less than 5 inches thick at the lift point. <br /><br />Like the other poster wrote: drop your engine down an a pallet with some old blankets on it. <br /><br />Good luck,
