hi, I ran this motor today, it has two plugs,, if i pull one plug wire,it runs & stays running half ,,if i pull the other plug wire ,it runs half, then dies in a few seconds,, if i run it with both wires ,it surges half power then full power,, i just rebuilt the carb,,new gas hoses , check for air leaks on gas tank,hoses, ect..i am guessing,,since i am not a mech. the coil?? any help at all is apreciated ,, 1970 40hp evinrude i also put new plugs in it thanks , as it was down to half power,i squeezed the bulb , it didnt help send more fuel,, tad
