Hi, I have a 1985 Johnson 15 HP boat motor on and 1978 alumicraft 15' fishing boat. I have just restored the boat and have run it a couple times....I am new to boats so this may or may not be a dumb question. I run the boat and I come accross times that the engine revs really high...the prop stops and motor is still in gear. This happens while I am moving (of course). I know the prop stops because the boat slows as if I let off the throttle but exhaust blows out like normal...My conclusion is that it does this because of weeds...is there some sort of mechanism inside the prop or gearbox that allows the prop to momentarilly disengage when it gets weeds tangled in it? If so, is there a way to adjust it so it doesn't do this for every little weed it comes accross? thanks a lot for all your help!!!!
