Hi all,<br />Got a strange one thats been happening for the last month or so. It a Honda 40, Tiller. Between 1000 and 3000rpm, doesn't matter where, If I hold the throttle at any given position, I'm getting a slight pulse in the RPM, Kind of at the rate of "one-and-and-two-and-three-and...". RPM's according to the tach seem to be holding steady, but theres a definite fluctuation going on. Hit the throttle and the acceleration is instantaneous so it must be something minor. Usually it doesn't happen at idle, only when I'm at no-wake speeds.<br /><br />Could I be getting a carb out of synch? I've ruled out the obvious. I've put on a brand new prop, the prop shaft is not bent. Primer buld is hard, not a fuel delivery problem. Gas tank is vented. Other that this, the engine runs smooth as ever.<br /><br />Anyone ever had this type of experience?<br /><br />Nav
