I’ve got down to the yard today and checked the leads which were all in the correct position.
my next thought was the joke and it was under quite a lot of preload and the plugs were quite sooty. So I released the preload on the choke and gave it 5 mm clearance from the carbody to the flap or the edge of the butterfly. I ran the engine again and allowed it to come up to operating temperature and it was still dancing around so I then turn the mixture screw in Silly gently bottomed out and backed it up by two terms I started the engine again and screwed it in until the engine began to stumble and then backed it off by 3/4 of a turn.I ran the engine again and allowed it to come up to operating temperature and it was still dancing around so I then turn the mixture screw in Tilly gently bottomed out and backed it off by two terms I started the engine again and screwed it in until the engine began to stumble and then backed it off by 3/4 of a turn
After doing this I needed to reset the idle screw on the camp late and had some preload to the barrel adjuster then started idling at 900 rpm with very little shaking. I did notice however that the idle creeps down 50 rpm and then up 50 rpm and then down and then up so I attempted to set the timing.
I realise that the bypass cable is required for the shift into wrapped so I spliced into the black cable coming off the distributor that goes to the shift interrupt and connected the black cable to the hot wire on the starter and made a loop which I inserted between the two white wires on the distributor connector block.I realise that the bypass cable is required for the shift into wrapped so I spliced into the black cable coming off the distributor that goes to the shift interrupted and connected the black cable to the hot wire on the starter and made a loop which I inserted between the two white wires on the distributor connector block. I then adjusted the timing in accordance with the information on the flame arrestor which was 1° before top dead centre.
I removed the bypass wire reconnected the black cable to the shift interrupted lead and the idle was still creeping up and down by 50 or so Rpm.
I called as a friend of mine who is an experienced marine eng friends and he suggested that the carburettor might need rebuilding and cleaning as the reason for the creep in the idle.
i’ve posted a video below and would appreciate your suggestions as I’m under pressure to get this boat working before it gets shipped to the Greek islands
https://youtu.be/E478otCbYKo
Thanks in advance
