SkippersMinnow
- Joined
- Nov 15, 2001
- 52
Had my boat out a few times and noticed the engine "runs on" on occasion, so I called the dealer. He said to let it idle a minute or two and then shut it off. I tried this the next time out and it still did it. So I had my 20 hour check up done, and I told them it was still running on when I turned it off. They told me they turned down the idle and it should be fine. I then had it with me on a weeks vacation, and now it idles at 550 rpm, idles real rough, and STILL runs on from time to time? It is a 2001 3.0L mercruiser with an Alpha 1 sterndrive. Any others with the same problem? I was asked if I was using regular gas, and I said yes. Do any of you run mid grade or premium?
