Engine Sensor warning
alexvelarde
I changed my impeller and ran the engine and everything was working fine. The next day I went out on the boat and I got an ?engine sensor? warning on my smartcraft gauge with two red lights.
I think the temperature was around 155-165 while running it on the water. No beeps sounded. There seems to be plenty of water pumping out the exhaust.
What could be the reason for this warning?
Chaparral 2013 SSI Wide Tech
5.0L MPI (305 CID) Sterndrive EC
260 HP
Engine serial number: 2A047298
Drive serial number: 2A064367
This could be a lot of things, but need to find out which sensor(s) is not working. Smartcarft should have a menu you can scroll thru, otherwise need to put a scanner on it
