Engine Size?
bobberii
Restoring a 1971 Larson Lapline 14ft. Had a junk 55hp on it. Took it off and looking for a replacement. I have seen similar boats to this having engine sizes from 35hp to 60hp. Any thoughts on what size would be reasonable? I would like to take kids tubing, but no interest in getting up enough for skiing.
Thanks
NoKlu
Re: Engine Size?
There should be a plate somewhere on it with the maximum HP rating for the boat.
bobberii
Re: Engine Size?
Nope, no engine plate or capacity plate. That's why I'm askin. Anyone out there with a 1971 14ft fiberglass in that engine size range?
Re: Engine Size?
Ayuh,... Ya probably otta be shoppin' the Same neighborhood, I'd think....
MTboatguy
Re: Engine Size?
I have a 14 fiberglass and my hull plate states 50hp max.
Yacht Dr.
Re: Engine Size?
Do you have some pics of this ?
Dont mean to be rude here..but a 71 14' larson restoration + repower..
Have you investigated your floor/trans ?
Might not be worth it... just me though..
YD.
bobberii
Re: Engine Size?
Sorry no picts yet. I posted before picts early last fall. Redid the whole interior. Floor and Transom intact. New Carpet, Seats, Steering wheel, installed a sterio and got the horn and lights working. All I need is an engine and trying to decide if I like the looks better with or without windshield. It's soley a winter project when my cruiser is on blocks, so I'm getting the garage ready soon. Just trying to get input to see if this guy overpowered it or will a 35hp be a dog.
Woodonglass
Re: Engine Size?
This will "Kinda" get you close to your HP rating.
The USCG determines the max HP rating for a boat as follows:
1. Multiply length x width at the transom.
2 If Length x Width is.........then max hp is
.........0 - 35.......................3
.......36-39........................5
.......40-42........................7.?
.......43-45........................10
......46-52.........................15
3. Except flat-bottomed hard-chined boats use the next lower rating.
4. If length x width is greater than 52, use this formula:
.......Length x Width x 2 minus 90, rounded up to the next multiple of 5.
............Example: my boat is 15.5 feet by 5.5 feet. 15.5 x 5.5 = 82.25 x 2 = 170.5 - 90 = 80.5
...................the rating plate reads "85 hp".
5. Except if the transom is less than 20" high *or* the motor is tiller steered, in which case:
..........Length x Width x 0.8 minus 25, rounded up to the next multiple of 5.
A boat builder doesn't need USCG approval to rate a boat at or below the USCG formula.
A boat builder can use a higher rating only if the proposed boat/motor combination passes handling tests designed by the USCG.
Source(s):
United States Code Title 46, Chapter II.
CFR Title 33, Subchapter S, Chapter 1.
My experience tells me that a 14' boat of your vintage should NOT go more than 50 hp and would more than likely be very satisfactory with a 35 - 40 hp. I have a 15' 1962 model with a 40 hp Rude' that is just fine.
I'm just sayin...:D
Steve Mahler
Re: Engine Size?
i have had similar boats, 50hp is right for tubing. 35 will probably plane along with light load but not alot for tubing.
bobberii
Re: Engine Size?
Thanks all. I'm going for a 50hp. I've been pullin the kids with my 28ft cruiser at about $200 bucks in gas a day. So I figure I'll save a bunch with this combo. Girls just wont have a bathroom:). I'll post picts in spring.
Yacht Dr.
Re: Engine Size?
You may be spending more time IN your boat. With no bathroom and girls ;) .
bobberii
Re: Engine Size?
Well I found a 1972 Chrysler 35hp outboard that matched the color scheme of the boat in question. That was mandatory per the admiral. It was cheap and it runs, so I am gonna set it up and hope for the best come spring. Thanks for the help, I'll let ya know how it goes and post picts when I get it set up in my dads garage this winter.
