I have a 15 hp Mariner outboard on a 10 ft tru-line sports cat. The boat is rated for up to 15 hp and 700lbs. It is a center console boat with a tri-hull. I am 220lbs. When I first go at full throttle the engine seems to slip occationally for approx 1 minute. Not sure what this slipping is but does not sound good? Eventually the boat reaches plane and the boat goes at approx 20 mph if no head wind or waves, add any rough stuff and the boat seems to never get back to plane. Also when my wife joins me (approx 150lbs) the boat never reaches plane. I have added fins and this seems to help when I am alone but with a little more weight it never reaches plane. The outboard is a long shaft 23" and the center measurement on transom to keel is 18". The fin on cavitation plate is approx 3 inches below keel. Also my water intake is on the underside the cavitation plate.
Would raising it up 2-3 inches help? I am thinking about buying a mini jack plate.
