captaingrubby
- Joined
- Aug 21, 2005
- 7
I just cleaned out my carbs with Seafoam because the idle was always rough and it had not been done in some time. Everything was good to go until I was adjusting my carbs adjustment screw to see if I could improve the idle. When using ears at home I got the idle perfect but on water testing did not go so well because as soon as you hit the gas it was instant "studdering" and it would not accelerate. On water adjustments were going pretty good... got it just right so it idled good and when I hit the gas she shot up on plane...YIPPEEEE... ..... THEN if I stopped the engine and tried it again... it would studder again for a minute or two... then blam... full power again. If I turned off and on .. same thing... every time. When I put the cover back on the engine it also had an effect on the acceleration etc. It ran better top off than on every time. <br /><br />Can anyone help...<br /><br />It's got new plugs<br />Compression is 131 cyl 2<br />Compression 135 cyl 1<br />New gear lube<br />Fresh Carb Cleaning<br /><br />What would make it so sporadic? I'm thinking something is wrong with the air/fuel mix with the carbs but it's totally incosistent.<br /><br />Any help would be GREATLY APPRECIATED
