redgoat
- Joined
- May 23, 2010
- 102
Last summer I replaced a shift interrupter switch (39671A3) on my 153 cu.in. 120 hp 4cyl Mercruiser. I considered my self lucky to find this NLA part at a local dealership. This seemed to solve my forward to neutral binding up problem. My perennial problem for many years was the stalling when hot when I would shift from neutral to forward or neutral to reverse. The engine would die. It would usually start right up again but would die when put into gear. Today it ran flawlessly for 90 minutes. An hour later it ran fine for an hour then started to idle rough and even stall. It would restart quickly but would die promptly when put into forward gear. I have thoroughly rebuilt the carb, recently installed an electronic ignition, new fuel pump and fuel filter, new plug wires and plugs, new coil, double gasket on carb base, adjusted needle valves, and set timing. I am aware of heat soak so I run my blower constantly to remove hot air from engine compartment. This Mercruiser engine is 45 years old but has been meticulously maintained. This problem existed on my old points and condenser ignition before I went electronic.
