Re: Engine stalls afters running
Need a few details, so I'm going to go the fun route!
Also, I'm sure you said this is the case, but I want to be 100% clear...you can run as long as you want, this problem only happens when you bring it back to an idle by yourself. Correct?
Ok fun time, I've got 2 questions for you about some further info on this condition...answer mine and I'll try very hard to help answer yours!
1.) This is right after you have the problem - i.e. you just did a half/full throttle run for a while, then tried to bring it back to an idle, and it stalled on you, like you said above.
Now, if you turn the key to start it back up (right after it stalls on you - like 10 seconds later...or without waiting a significant period of time).....
What does it do?
Does it:
a.) start right back up and idle ok?
b.) start right back up and NOT idle ok? (won't idle now that it's fully warmed up)
b.) hard to get to restart but idles ok once restarted?
d.) hard to get to restart AND NOT idle ok now?
e.) NOT restart at all now, and you have to wait a while?
(If somehow there should be an f. needed below because of something very strange that I missed, please explain that also)
2.) Has anyone done any work on this lately? By that I mean, did you NOT have this problem prior to ANY tune-up and/or repairs, and now after something's been changed, poof - it's doing this? OR has this problem just come out of the clear blue?
Let me know,
Thanks.
