Stinkytoots
- Joined
- Aug 19, 2013
- 22
I have a 1979 Evinrude 85hp model #85999r. Over this winter I rebuilt the lower unit, replaced both shifter cables, cleaned and rebuilt carbs to spec, replaced spark plugs, replaced fuel lines and rebuild the fuel pump. After completing these items, my 1st time taking it out it purred at idle but still died under load if the engine wasn't warm. Once the engine was warm it seemed to be a finely tuned machine.
Wile on a fishing trip last week, the starter bolts stripped out leaving me on the lake with my boy as I used my foot to keep the started on place so we could get back to the cabin. That day I used a Hele-coil kit and replaced the starter.
Since then the engine will not stay running warm or cold at idle rpm's 8k. last year I had the problem of the engine dying when I put into gear.
Should I increase the idle rpms? What can I do to prevent the engine from dying when placed into gear? I was originally thinking it was a fuel problem, thats why I rebuild the carbs, the fuel pump and replaced the fuel line.
