satnghtracer
- Joined
- Jun 25, 2006
- 9
when i put the shifter in reverse the engine stalls.
satnghtracer said:when i put the shifter in reverse the engine stalls.
satnghtracer said:found out the problem the limit switch on the gimble ring for all the shifting controls was triping.
Don said:satnghtracer said:found out the problem the limit switch on the gimble ring for all the shifting controls was triping.
There is no limit switch on the gimbal ring that has anything to do with shifting controls. All that limit switch does is keeps the drive from being TRIMMED up, without using the trailer button.
Has absolutly nothing to do with the ignition or shifting, unless someone has the wiriing all screwed up.
Bond-o said:Don said:satnghtracer said:found out the problem the limit switch on the gimble ring for all the shifting controls was triping.
Ayuh,..........
And,.....
If by Chance you're talking about the Interupter Switch on the Shift Bracket, that's Sticking,+ Shutting Down the Motor,............
Replace the Lower Shift Cable,........ Like Don said in his 1st reply to Fix It......
It's NOT the Switch,... Or the Bracket,... Or the Adjustments.......
It's the Lower Shift Cable..........
