Dirty Dawg
- Joined
- Sep 7, 2008
- 172
Hello all, been away for a while, no not prison, good tho see everyone is mostly still here. Need some help, ran into a problem today when I went to winterize the boat. Had some trouble starting the engine. Had to really push the throttle down, the engine would rev up heavily and stall in about a second or two. Finally after trying a few times I got her started. Engine started right up after it warmed up. I changed the oil and filter and went to restart it and again the same thing happened again.
Again, the engine would run for approx 1 second and would stop. This time I could not get it to restart no matter how long I tried.
I am wondering if the lanyard safety switch could be bad. It seems to me that when th switch is off and you try to start the engine it does a similar pattern. Although I cannot be certain, is there any simple way of bypassing the safety switch w/o disconnecting the throttle? How does the lanyard switch stop the engine from running?
The boat had a similar problem toward the end of the season, but again after a while it stated and then the season ended before I could come to a conclusion if there was an issue.
What do you all think? If it is not the lanyard safety switch what else could I look for? There is spark at the coil and at the plugs , I see a blue spark, not sure it it is strong enough since I have nothing to compare it to. When I turn the key I hear the fuel pump turn on and I can see gas fuel being shot into the carb, But I do not know if it continues to feed fuel.
Need to get her going to finish my winterization so any help or ideas would be appreciated!!!!
She is a :
2000 210 Sea Ray Sundeck
5.0L Mercruiser Alpha One Gen II
Thanks Again ike
She is a :
Thanks Again ike
