I have a MerCruiser 3.0 that is giving me some troubles. For the first 5 to 10 minutes of Cruising at 75% throttle it runs great a smooth. Then it starts to miss a bit Then it starts to miss a lot and slowly loses power. When I pull power back it still does it at a lower speed once it starts doing it. After the boat sits for 20 minutes or so not running it’ll be fine again for 5-10minutes then it starts acting up again. If I give a full power wall it’s acting up it’s sputters and occasionally sounds like it’s pinging/pre-Detonation? I’ve tried to take some video for the audio I will upload those to YouTube shortly. But it’s kind of hard to hear with the wind noise.
Temperature sits at 170, oil pressure sits at 40. I have a brand new carburetor on it. The old one was giving me similar problems but it also had a sticky float and had some corrosion. It has brand new plugs and fairly new cap/rotor/wires.
I set the timing per the book. I jumped the timing wires on the coil and set the RPM with laser tach at the engine.
Any suggestions would be much appreciated weather is starting to be really nice. I’m tempted to just take it to the shop.
