longstand
- Joined
- May 2, 2009
- 293
I install a new carb.
Install New Intake Gasket.
The engine Idle good. but ones i put it on Forward or reverse gear it BUGS down and Die..
The whole reason i replace gasket and install new Carburator is because of this..
Its better now than before but. it still BUGS Down and shut off..
i have not set the timing yet.
the Fuel is kind of old. i put Water Remover 3 weeks ago...
i have remove the gas line that connect to the carburator and see if it pumps alot of gas everytime the engine turns and its spray alot of gas. so thats tills me its pumping gas.
also when i open the butterly without putting the boat on gear. the carb works fine..
will it help if i make a video??
