After suffering recent engine failure on my 1968 55HP Evinrude, I've now replaced the Amplifier<br />Assembly, Points, Coil and Battery plus have had the Starter tested. I've disconnected all engine<br />wiring connectors, cleaned each terminal and performed a continuity check. The same on all<br />grounds, plus I've replaced any bad connectors or frayed wires. I did the same on the entire<br />boat from ignition to battery, from battery to engine. <br /><br />From a cold start engine starts right up and runs perfectly for 12 to 15 minutes and then shuts<br />down, if you try to restart immediately after shut down engine will turn a half turn pop through the<br />exhaust then kicks the starter out of gear. If you wait a minute or two it starts right up and runs<br />for 4 to 5 minutes and shuts down. You can do that for hours, it's like something is heating up<br />or shorting cause engine failure. Could the solenoid cause this?
