79 140 Johnson just rebuilt carbs and fuel pump. Water tested for a couple of minutes and it ran great, idled smooth, started right up.
Installed motor on different boat, took for a test run and all was well. Newer boat has built in gas tank. When I tested it it was using a red can. Went home put gas in built in tank. New warer separator, fuel lines. I started the boat on muffs and ran it in the driveway. Water tested it and it ran great for 5 minutes. Stalled out then would run fine then start surging and running rough. Boat wouldn't idle. When I would pump the ball fuel would pour out the carbs. Did I bend the floats? Is it maybe some kind of air in the fuel line or water seperator? Did I blow the fuel pump pulling fuel through the new water seperator and lines?
