ENGINE SURGING
Fireman81
Hello,
I have a 1992 Johnson 40 hp outboard that starts fine and idles fine but when I take it out on the water I can get up to speed for the first couple hundred yds or so then it starts surging. My guess is a dirty carb. what else could cause this?
Overheating ?----Have you checked water pump impeller ?---Or perhaps run with a different tank and hose.
Chris1956
Pump the primer bulb and see if the surging stops. If so, rebuild the fuel pump, clean the fuel filters, make sure the tank vent is clear.
Fireman81
I have not checked the impeller but I do have a steady stream coming out.
Also have not checked a different hose or tank. I forgot to mention that I have gas coming out the overflow breather on one of the carbs for sure.
