Engine Swap 3.7 Mercruiser to 4.3L GM
Status
Not open for further replies.
puddles76
So my motor is shot. Rebuildable yes but non running at the moment. It's the old 4cyl and is about 165hp in a 21ft boat. It ran well for a long time but now that it needs to be rebuilt I wonder if I should upgrade to a 4.3L. I can get a turn key 4.3L for an extremely good cost so I'm not worry about the money there. The 3.7L will be about $4400 (removed, rebuilt and reinstalled) So my question is it possible to put the 4.3L in with out too much of a headache.
Don S
Re: Engine Swap 3.7 Mercruiser to 4.3L GM
If you are replacing the engine along with the drive and transom shield, and you have stingers in the boat for side motor mounts, yes it's a FAIRLY easy change. But if you are trying to change engine only, then you may have a lot of problems.
Ayuh,.... You'll have to define "too much of a headache".
It's Not a Plug & Play situation...But not all That hard in My book...
Eute
What is involved in changing out to a 4.3 only? im looking at this option as well
Don S
The replies have already answered the question.
If you have a question, please start a new thread of your own and ask for the informtaion YOU need.
Status
