so i broke down and bought a new 4.3 ltr vortec to replace my older one with a crack in the block somewhere. did the install with a marine mechanic, swapping the parts and all that jazz. we ran her in the shop to time before replacing in boat. was having an issue with keeping it running for more that 30-45 seconds before she conked out. however it would fire back up, not running well when we opened up throttle, but enough to get it timed, or at least close. replaced in boat but it would still not run for more than 45-60 seconds. come to find out the oil pressure switch was bad. replaced that and had no issue with it running, but... when applying throttle it wants to bog down and sputter at between 1500-2000 rpms. could this be bad timing when we tried to time it when it was starving for fuel? its got new plugs, wires, filter, etc...
