Re: Engine Swap
I've pulled a few motors out of boats and cars. <br /><br />The main problem with a boat is its transom height, I doubt if you will be able to use a conventional cherry picker. I used a backhoe, called a guy who had one in my neighborhood, explained what I was doing, said it would take less than an hour and asked for his minumum, remember to double the price , he will have to come back to reinstall it. He charged me 50 bucks and didn't charge me to come back after he saw how easy it was.<br /><br />Other than the method of removal, a boat engine removal is easier than a car. If you are spending the time and cash for a new motor, you might as well (man expensive words!) have new bellows, shift cable, gimble bearing replaced by a pro and engine alignment, about 600. And you gotta replace the manifolds and risers (easy to do yourself), since price differs on each motor do a search, I got good prices on basicpower.com. You really have to do all of these things, add it up, compare it to the value of the boat and deceide if its worth it now, before you start. This is when you realize it may not be worth it, check for floor rot, stringer rot, condition of seats, batteries, trim pump and cylinder operation, etc.Ask yourself if you really like this style of boat or if another one would suit your style better. If its too much, sell it now in the spring and count yourself lucky.
