Engine Temperature on V4's
eriefeelin
Hello I have a 1989 OMC SeaDrive 115.I installed a temp. gauge and sender on both cylinder banks.Does anyone know why the right side (140*) runs about 10 degrees hotter than the left side (130* at cruising speed)?
The engine runs very good just curious as to why.
sony224422
Re: Engine Temperature on V4's
dhadley has said that it is a normal thing for the starboard side to run hotter than the port, and that it is usually the side that has a problem if something breaks.
