First, thanks for replying to my last questions.<br />And Yes I have another.... <br /><br />I have 2 cables one for the gear box and one for the fuel. The handle has a trim button and a neutral position when you pull the handle to the center of the boat. Here is the problem. It wont go into nutrual and when I push the throttle forward the cable will not return to its neutral position or reverse position. I've taken the panel off and removed the cable form the carb and I can manually move the cable back and forth with hardly any effort but the throttle handle doesnt move and as soon as I put the panel back on the boat and try to move the throttle it seems to be stuck. I dont know what year the contols are but the boat was made in 87. What normally fails on the contols and can I repair this thing? Would greasing it help?
