Ok guys... need some help. I have a 1995 mericruiser 3.0lx with a alfa 1 gen 2 outdrive. Here's the problem. I was having a no start issue when we arrived at the lake. I wasn't getting any spark . I just did the regular maintenance which included an new distributor cap and rotor. I decided to check the kill switch on that's on top of the valve cover that kills the engine while shifting gears buy bypassing it. No start didn't change. I went ahead and started checking all the connections to the distributor and I forgot to connect to connector which has the 2 white wires ..when I turned the key The motor started. When I reconnected the connector with the 2 white wires the engined died. ..what could be the issue..any help would be great considering we are at the lake and I'm trying to get this thing going to get back into the water.
