Engine troubles
I have a 1995, Nitro-160 with a Mercury 3 cylinder, carbed, 60 HP engine.<br /><br />Since Xmas I have overhauled the carb's by removing and completely rebuilding them, removed gas tank from boat and replaced all hoses. Removed the tank hardware and cleaned and replaced what I felt needed it. Ran the equal of "gumout" three times through the tank prior to reassembling the tank.<br /><br />2 weeks ago the boat was placed in the water and except for running a little rough for about 10 minutes, it straightend out and ran just fine the rest of the day. This trip was a maintenance cruise with a little fishing. <br /><br />Yesterday, It was very difficult to keep running when cold. It would start up after choking it, then sounded like it starved out. I had pumped up the bulb prior to launch. It took a couple minutes of slowly advancing the throttle to keep it running. After a few minutes, it ran fine, WOT ran at top speed without a problem, slowed down, trolled with the engine for a little while, NO problem. Used the trolling moter and then tried to run the big motor, same as when first placed in the water, ran rough, "coughed" a couple times, warmed up then ran fine. I did adjust the carbs idle mixture as explained in the Mercury manual after it warmed up prior to the first test this year.<br /><br />I am slightly confused on what to look for><br /><br />I plan on attempting re-adjusting the carbs at idle again. did like the manual says the first time..<br /><br />Has anyone else had a similar type engine act this way?? And what do you do to fix it??<br /><br />Thanks for any help or advice,<br /><br />Michael
CTD
Re: Engine troubles
Sounds like it runs fine once warmed up. Lean when cold, does it have an electric choke? Is there an enrichment circuit for cold operation? Thermostat working ok?
Re: Engine troubles
It has an enrichment circuit and it appears to be working, Thermostat appears to work,<br /><br />enriched it several times and it did run at a higher rpm, then slowed down and "starved" sound came back.<br /><br />Mike
