alley mechanic
- Joined
- Apr 15, 2011
- 100
Hellow i have a question about using omc (brp) engine tuner, i know that it needs to be done every so often to clean up the carbon on the pistons and around the rings as to help the motor have good compression but my question is does it also help clean up or free up the recirculation check valves on a 115 v4 maybe a tech could could answer this for me , i dont have a problem but i was wondering if the engine tuner also helps clean up other areas on a outboard.
Thank you
alley mechanic
Thank you
alley mechanic
