WillandShay
- Joined
- May 31, 2011
- 149
OK. So I am going to step through everything we did to day to the "Shae". Yep that is what Shay named his boat because "Shae" is the female version of "Shay". Anyway back to it, I am going to number them for ease of answering if you all wish to do so...
1. Battery had 11 volts, this might be a problem but watch the videos and see how fast she did turn that engine. This battery will not be in the Shae, once she is ready to set sail. At the end of a session of turning and turning and turning that engine over, she puked and spilled electrolytes.
2. Distributor cap is completely broken at the left base screw area, but just at the base. Rotor button looks great and the points fired off as well. It gets fire but the fire is weak and sporadic, going to replace the cap, wires, plugs, etc... But will probably keep what we have until it at least fires off one time, even for a second. The spark is very weak it seems...I know this because at dark I took the plug out and connected the wire to it and turned the engine over, and sometimes the spark was consistent and then the spark was not there at all, no matter how many turns the engine went.
3. Fuel pump never pumped fuel in the carb, going to run a hose straight from the gas can to the fuel pump tomorrow, so for today I dumped about 5-10 CC of gas straight down the carb, and this is right before Shay had a go at it in the videos. Just trying to get it to bump over once. I was hoping for him it would, but it didn't. Thinking about starting fluid...hmmmmm....we will see.
4. We were unable to turn the engine over with the key, as the relay did nothing but buzz, I was thinking that may be amp related, or it may be just where this boat has set outside for so many years, uncovered, that I just need to rewire it all. Redo the console and gauges. Could not get the blower motor to work, nor the bilge pump to work, so that tells me the wiring is shot. At least I think so. The stern light and bow light did work for a bit, then as the day went on, they did not work anymore.
Any suggestions, ideas, or anything is welcomed. I will try what ever you all suggest, but for now, I think it is just a matter of replace this, try it, replace that, try it, etc...
If I think of more items I will post them, but these are the first on my list.
Thank you!
Will
Thank you!
Will
